Is there any way to control the format of a hole table that is showing datum points? A couple of areas have proven difficult:
Any help with this would be greatly appreciated.
It would be very beneficial to have more control on the hole table creation.
Your suggestions also apply for my application.
I hope someone can points us into the right direction.
Johnny
If you have maintenance, please take a look at the following article - CS98777 Can hole tables be filtered on a Pro/ENGINEER drawing.
If you are not able to access the article, here is a snippet of the resolution:
Let me know if that answers the question or not.
Amit
Thanks for your answer.
I don't know if these workaround are suitable for my application.
I have to check.
