GD&T True Position Tolerance Appearance In Model and Drawing
zientarad
2-Explorer
Hi everyone,
I do not want my true position tolerance showing up like this with the long leader line. I want it to show up with a short leader line that ends when the text starts. Does anyone know how to change this setting? See attached.
To create this GD&T I was in the .PRT file, annotate tab, and picked on "Geometric Tolerance"
Then clicked on the hole note and all of a sudden my nice looking short leader line turned in to a long leader line. It ALSO shows up this way on my drawing.
Dan
5 REPLIES 5
j_k
8-Gravel
8-Gravel
(To:zientarad)
Anyone have an answer?
JK - Creo 6.0.4.0
StephenW
(To:j_k)
@j_k
Try changing the text orientation under display.
TomU
(To:StephenW)
@StephenW,
That only works for dimensions.  This is a standard hole note.
TomU
(To:j_k)
It seems to be caused by the leader being from a note instead of from a dimension.
You could open a case with tech support and ask why, but I'm guessing they'll say it's is "working to spec".
Chris3
(To:zientarad)
If you create an idea for this I will vote for it. I played with Creo 10 (early build) briefly at the Orlando conference and I can report that it does the same thing there.
