GROUP COPIED_GROUP OPERATION
555mathew
3-Newcomer
Hello Experts,
I tried recreating a "Group COPIED_GROUP" feature with copy and paste special command but ended up with a different "Moved Copy"  feature in model tree (Moved Copy 2). I was able to create the feature successfully  even though model tree looks different.
Which command should I use to replicate the "Group COPIED_GROUP" in the model tree in the attached image.
Mathew
2 REPLIES 2
Got the answer for this.
Command -  Operations>Feature Operations>Copy.
You may mark your reply as solution of the post as that is actually answer of your query.
