Check your config settings. I think by default anti-aliasing is set to 8x or something in Creo11. Turning that off will make the text sharp again like it was in 8 But be warned. We are fighting another issue in Creo 11 where when you click something..it doesnt always get selected. (even though its already pre-highlighted) This happens in 2d drawings for dimensioning and also in 3D when selecting surfaces for something for coloring or measuring in 3d.
PTC has been unable to reproduce this on their end. Even though we have probably 20 computers here all showing the same symptoms. 😞
You posted this on the community board, not PTC Tech support. You may get some help here within the community but if you want to open a tech support ticket, please try that again and make sure you don't let it direct you to make a post on the community.
FYI ... you posted your question on the user community website and not on the PTC support website. Please contact PTC Support.
