Hi dearz
I have got a problem with my selection of model in proE sketching window.let i want to select an edge or surface and as i move the mouse over them then the other things like datum planes or axis or other things highlights and dehilights slowlys which waste to much time.also when i select some edge or any thing else it takes too much time.my Pc built in video card is 256 mb.Is this a video card problem or any thing else?
You postet in forum CoCreate-Modeling, but talk about ProE.
Which system do you use ?
In CoCreate-Modeling you can justfy the time for the mouse-over functions.
This will be found in the settings for windows at the tab "flyby".
