Greater Than Or Equal To Sign
mjenkins
Can anybody help me out on the procedure to insert a greater than or equal sign into a ProE drawing?
I found the Alt code is Alt-242 and it shows in the properties box but when I close the note, it just shows as a box in the drawing.
Got some good replies. What I had to do was copy all the ttf files from:
"C:\Windows\Fonts"
To >
"C:\Program Files\proeWildfire 4.0\text\fonts"
Then I picked Arial and it showed up just finewhen I used Alt 242.
I need a little help with a draft. On this part (this is a sample, not
my actual part), how can I get the draft to split along the center-line
of the part? We will put in 3 directions with this mold, 2 normal to
the orange plane shown and 1 up away from the cylinder end. I would
like the 2 semicircles to look the same. At this point, I can only get
them to split at one point that is off-center. Since the cylinder was
made first, the circular surface acts as one, and not 2 surfaces.
Tony
