Hi, i have a fail datum plane in an assembly? and now i don't need it anymore. How do i delete it?
If that datum plane has no dependent features then you will be able to delete it.
i cannot find the features in the assembly... so how do i delete it?
Ok. then may be this datum is created as an internal datum to a feature and so it is not visible in the model tree.
Try to use the Find tool to search this datum and locate the feature that is using this datum.
still cannot find. please see photo below. it's not in sub-assembly.
is it possible to attach the file here?
it's too big. anyway, it's not a big deal, just annoy me a bit.
It seems like there is a missing model that has a feature that this failed datum is referenced.
see information in https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS42476 document.
MH
