HOW TO DELETE THE SYMBOL'S USING VB-API
avijayan-2
HI EVERYONE,
I AM FACING FEW ISSUES WHILE I AM TRYING TO DELETE THE SYMBOL INSTANCES FROM CREO DRAWING TEMPLATE.
I WILL EXPLAIN IT BRIEFLY:
I HAVE A CREO DRAWING TEMPLATE WHICH IS HAVING MANY SYMBOLS FOR Eg: REVISION BALLOON, SURFACE FINISH etc.WHAT I WANT TO DO IS I WANT TO DELETE SOME SPECIFIC SYMBOL INSTANCES FROM THE DRAWING LIKE.
1. I HAVE SURFACE FINISH SYMBOLS FROM Ra0.6 TO Ra1.8 IN MY DRAWING BUT I WANT TO DELETE ONLY Ra1.8 FROM MY DRAWING.
2.SIMILARLY I HAVE REVISION BALLOON FROM A TO Z HERE TOO I WANT TO DELETE ONLY A SPECIFIC INSTANCE WHICH USER IS GONNA SELECT.
WITH THE HELP OF Mr Parthiban Kannan‌ I HAVE ALMOST REACHED THE LAST STAGE, BUT NOW I AM FACING ISSUE IN SELECTING THE INSTANCE OF THE SYMBOL.
BELOW GIVEN IS THE CODE:
Public Sub findsymbol(ByRef session As IpfcSession, _
                                   ByVal symbolname As String, _
                                   ByRef TextBox1 As String)
        Try
            Dim model As IpfcModel
            Dim drawing As IpfcModel2D
            Dim symInstructions As IpfcDetailSymbolInstInstructions
            Dim symItem As IpfcDetailSymbolInstItem
            model = session.CurrentModel
            drawing = CType(model, IpfcModel2D)
            Dim i As Long
            Dim TotalSheets As Long
            TotalSheets = drawing.NumberOfSheets
            i = drawing.CurrentSheetNumber
            For i = 1 To TotalSheets
                Dim owner As IpfcDetailItemOwner = CType(drawing, IpfcDetailItemOwner)
                Dim symbol As IpfcDetailSymbolDefItem = owner.RetrieveSymbolDefinition(symbolname, Nothing, Nothing, False)
                MessageBox.Show(symbol.GetInstructions.FullPath)
                symInstructions = symbol.ListDetailItems(EpfcDetailType.EpfcDETAIL_SYM_INSTANCE)
                symInstructions.TextValues = TextBox1                 (GETTING ERROR IN THIS LINE)
                symItem = symInstructions.TextValues
                symItem.Remove()
            Next
        Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
        End Try
    End Sub
THIS IS HOW MY FORM LOOKS :
a) FIRST BOX IS FOR SYMBOL NAME
b) SECOND ONE IS FOR SYMBOL INSTANCE WHICH I WANT TO DELETE
ERROR WHAT I AM GETTING :
With Regards
Aghil.M
1 REPLY 1
Hi Aghil,
did you get your code to work?
I also want to go through all symbols on the drawing and get the coordinates of specific symbols.
Adding symbols work, but getting all symbol instances and their info not. Can you paste your code?
David
