I am using Creo Parametric 4.0, I wanted to create a simple cable drawing. I started with creating a 3D routing of the cable set that consist 2 connectors connected with 2 cables. Once I flatten the cable set one of the cables is shorter due to it's routing. I'd like to ask if there is a possibility to connect it to the connector for a drawing purposes. Maybe there is a way to fix the length so the cables uld be equal.
Thanks for all suggestions.
