When setting the lower tolerance of a dimension to 0.000 it disappears. It is fine in the model. This happens for created or shown dimensions.
Wayne,
Try setting drawing option blank_zero_tolerance as no.
in your dtl file, you need to set
blank_zero_tolerance NO
don't forget to regen
