Help the Handicapped....
PeterBrown
7-Bedrock
Hola -
I'm looking for some direction regarding Harness. We've been using Pro/E for about a dozen years and all the equipment we manufacture is in Pro/E (we're an OEM). One aspect that we have not integrated is the wiring/harness/wiring diagrams. Traditionally, that has been done in 2D format in Autocad. As our products have become more complex, this is no longer tenable - we need accurate BOMs. I'm interested in doing harnesses and control panels currently, no printed circuit boards or things of that nature.
So basically, I'm starting with a clean sheet of paper. I've heard mention of Mentor Graphics (VeSys), CADENCE, etc.
Whatapproach would you recommend?
TIA
Peter
2 REPLIES 2
jellis
(To:PeterBrown)
Hello Peter.
We are running Creo 2.0/Windchill 10.1. We use Creo Schematics 2 (was RSD) to develop the schematic and logical references then output the xml file for importing into Creo Parametric. The Cable/Harness is developed in the 3D model then a drawing that includes tables for the wires/connectors/etc is created for the Flat Harness. This 2D drawing from Creo Parametric of the Flat Harness is what goes out to the Harness manufacturer.
KR, Jim
