Im having an issue when I attempt to constrain 2 parts from a 6bar assembly to my full assembly using pin joints so that they stay fixed when I run it. However when i select the axis' and use the front part plane with the front asm plane for the translation i receive the message "Connection definition incomplete". I have used this before and it has worked fine.
