Using Creo 5.0 and no matter what i do i cant seam to hide the solid pipe center line after making pipes in the model using the piping tool. I tried PIPE_SOLID_CENTERLINE and set it to no. That made no change. I hid all the piping lines and that makes no difference. The only way I can hide the center line of the pipes in my drawings is to hide the Solid pipes them self. There are many drawings i want to see the solid pipe just not the center line. I'm at a loss that should be an easy setting to change. Please help.
There are a few things you need to do to make sure the pipe centerlines don't show up:
You might also have to take a look at your layer settings in both your 2D drawing and your 3D model.
More details here: https://www.ptc.com/en/support/article/CS44077
The other thing you might have to do would be to check the properties you are using in your drawing view:
Hope this helps!!
James Sullivan
Thank you James Sullivan. This worked perfectly which I find to be a rare occurrence when searching for help on Creo issues. Note: made config changes but wasn't until I changed HLR edge display quality from follow environment to low did the centerlines disappear from the drawing.
Jay - Creo 6.05.
