Highlighted dimensions cannot be regenerated
PThapar
I am using creo 8 with windchill 12.
I have multiple drawings where I run a model check, and get the error "Highlighted dimensions can not be regenerated". However, there are no dimensions on the drawing that are highlighted!
This error prevents me from proceeding with a promotion request. Any ideas on how to understand what dimensions are causing issues?
PThapar
(To:StephenW)
Hey Stephen,
After many months, I finally got around to dealing with this issue because it became more of a problem.
The issue was my custom environment color settings. I changed the environment colors to default, and I was able to see dimensions highlighted.
Thanks for your support as always.
4 REPLIES 4
StephenW
(To:PThapar)
Check in the drawing tree when in the annotate tab. Maybe there is "hidden" dimension, they will be grayed out.
PThapar
(To:StephenW)
Hey Stephen,
This reply is a bit late, but this didn't work, none of the dimensions are greyed out.
StephenW
(To:PThapar)
I'm not really sure how to troubleshoot this problem without the actual model and drawings. Can you share the model/drawing as an attachment (zipped)?
Does modelcheck give you any information on the dimensions?
Usually with unregenerated dimensions, I suspect those are dimensions that are created in the drawing, I think.  Is this error a modelcheck error or  the error that appears in the message log?
PThapar
(To:StephenW)
Hey Stephen,
