We are on CREO 4, M080. On a drawing, we show a hole feature annotation note and the leader is as expected, off the front line of text. Then we attach a GTOL to the note, and the leader changes to underneath the last line and places the GTOL all the way at the end of the leader. What is/are the option/s that are controlling this? I have never seen this behavior before.
This is what we get:
And yes, this is just a simple example, we know the GTOL isn't correct.
What we want is this:
The above was created by creating an unattached GTOL, and then use the & id code in the hole note.
This is just a work around, there has to be a better solution. One that doesn't make the use go thru extra steps.
Thanks in advance!
