I am using Creo Parametric Release 4.0 and DatecodeM110
Information contained within a hole table on a drawing. Is there a way of showing the blind depth of a hole in a hole table, if so where can I find instructions? I had a quick try using parameters but I couldn't get it to work. I am also seeing standard holes labelled as M16x2 when in fact they have been specified as clearance holes, the only work around I have found is to create a normal hole at a specific diameter rather than using a standard hole generated using the iso.hol file.
This is possible.
Start here for method to implement this.
https://www.ptc.com/en/support/article/CS44121
http://support.ptc.com/cs/cs_27/howto/dwt3444/dwt3444.htm
