How can I bring back AFX/IFX minitool bar?
mvitárius
So basically I was using Creo 4 and use to have the minitoolbar for AFX and IFX now I'm on a brand new install, and I missing both. What do I need to do to bring back the minitoolbar for buw products?
which Creo version and which AFX/IFX version are you working with?
I think the minitoolbar is availalbe since version 6.0
For version 5 we added it for IFX in version 5.0.1.1.
For IFX 4 it was never available.
There is an hidden option to show it.
Browse to  <ifx/afx>\text\resource\dlg_config_*.xml
There you find an option 'ENABLE_MINITOOLBAR'
You can set the default value to 'YES' to show the icons in the minitoolbar.
Oliver Gräbner
B&W Software GmbH
Oliver Gräbner
B&W Software GmbH
Works fine, thanks. I'm sure it was in 4.***.
It was an integer option on afx though.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
