Hi, The situation is that I have an assembly of 5000 entities and I am trying to convert it to .obj file but the only way I can find is by selecting the entities individually. Is there a way or command that selects the entire assembly?
Thanks, regards.
Did you use the "all" button and select a coordinate system?
