Creo tells me that embedded components in an inseparable assembly are missing:
How is this possible? My understanding is that those components are saved in the assembly file-how can they be missing?
The missing components look to be instances within a family table.
Do others have access to this family table.
Could the instances have been renamed / deleted?
@Dale_Rosema wrote:The missing components look to be instances within a family table.
Why do you think that? Is it the "<<..>>"?
The whole assembly is an overlap of two imports.
I tried to rename the assembly, and learned that embedded components cannot be renamed (via renaming the assembly) and for missing embedded components not even the reference to the original assembly name is changed.
@Dale_Rosema wrote:Do others have access to this family table.
The whole assembly only contains imports. I did not find any indication that there are any family tables involved.
