How difference template in Creo 9.0.4
SS_10704479
8-Gravel
I would like to know that what's different templates as below;
mmns_part_solid_abs
mmns_part_solid_rel
solid_part_mmks_abs.
Please help me to clearly understand these templates.
kdirth
(To:tbraxton)
You are correct, I got that one mixed up.
See below:  Basically they are different model settings in the templates.
mmns_part_solid_abs   millimeter / newtons / seconds / absolute tolerance
mmns_part_solid_rel  millimeter / newtons / seconds / relative tolerance
solid_part_mmks_abs.  millimeter / kilogram / seconds / absolute tolerance
tbraxton
(To:kdirth)
@kdirth, unless something changed beyond Creo 7 I believe that the abs and rel labels refer to accuracy and not tolerance. I have not used Creo 9 so I may be wrong.
i.e.
mmns_part_solid_abs   millimeter / newtons / seconds / absolute accuracy
Involute Development, LLC
Consulting Engineers
kdirth
(To:tbraxton)
Thank you  your giving  knowledge.
