I need to create an shrinkwrap with just the outter surface to create a single "solid with no voids" part file. When I use the shrinkwrap with MERGE-SOLID it is still showing all the void areas inside my assembly. What I need is sort of like a facet model but using the outter surfaces of my assembly to genertae the part.
Using merge solid option
Using Facet option
