How do I setup Mfg documents in Creo( setup sheets,tool drawings etc.)
atribuzio
How do I setup Mfg documents in Creo? (setup sheets, tool drawings etc.)
SteveLucas
(To:atribuzio)
Anthony,
You can try the process documentation under the applications tab which is relatively easy with the help documentation in Creo. or Create a custom report using report parameters and drawing models that is more difficult to setup.
