How do i get info from a Creo MBD model to a Zeiss Calypso??
hjorg
Is there anybody using and transfering info from a Creo 2.0 MBD model into a Zeiss Calypso CMM?
What info can be used and how to?
3 REPLIES 3
GabrielZaha
(To:hjorg)
Depending what modules you have in Calypso you can import the 3D model and use the model to define your measurement plan. I'm not sure what formats are available by default. Also there is a direct interface for ProE / Creo. This one is a additional module that require specific license.
I wish I could tell you more but I'm just starting to learn Calypso and that is what I got so far in terms of interaction between Creo and Calypso.
You should be able to export an ACIS (.sat) file from Creo and import that into Calypso.
This is the approach we currently take.
