We created symbols of tables (i.e. torque table) in an mbd in Creo 8 but when we export them into a pvz file the justification of the symbol text changes from center justified to right justified so the text violates the table lines. These same files exported correctly with my old computer, but i had to get a new one and have a new config.pro. Is there a setting that controls this?
if you think that the problem is related to config.pro then:
If you upload both files, I can check their contents using Notepad++ functionality.
Thank you for your response. Unfortunately I lost the old config file when I switched to the new computer. I guess the next step should be to find someone in the company who can export the model/symbols cleanly and compare their file with mine.
