How do i get the PVZ file to preserve the justification of symbol text when exporting an MBD in Creo
EH_562926
3-Newcomer
We created symbols of tables (i.e. torque table) in an mbd in Creo 8 but when we export them into a pvz file the justification of the symbol text changes from center justified to right justified so the text violates the table lines. These same files exported correctly with my old computer, but i had to get a new one and have a new config.pro. Is there a setting that controls this?
if you think that the problem is related to config.pro then:
  • sort both files (old and new ones) alphabetically
  • compare their contents
If you upload both files, I can check their contents using Notepad++ functionality.
Martin Hanák
Thank you for your response. Unfortunately I lost the old config file when I switched to the new computer. I guess the next step should be to find someone in the company who can export the model/symbols cleanly and compare their file with mine.
