You can create the Draft feature and use Split by split object
I am having trouble creating a draft feature on my part and am not sure why. Can you use a curved solid surface as the pull direction or does it have to be planar?
Hi Laura,
here you can find all examples - How to create a Draft feature with Creo - http://4kside.com/en/videoportal/ProE-Creo-video-tutorial-23.html
thank you
