How to Create Draft with Creo Parametric 1.0 - 3th part
VladimirPalffy
You can create the Draft feature and use Split by split object
Best Regards,
Vladimir Palffy
3 REPLIES 3
I am having trouble creating a draft feature on my part and am not sure why. Can you use a curved solid surface as the pull direction or does it have to be planar?
Hi Laura,
here you can find all examples - How to create a Draft feature with Creo - http://4kside.com/en/videoportal/ProE-Creo-video-tutorial-23.html
Vladimir
Best Regards,
Vladimir Palffy
thank you
