How to Export Individual Sheets to Pdf in JLink
ddhini
Here Is my code to Export drawing File .But I want to export sheets Individually .Please guide me to solve this .
My code :
PDFExportInstructions Mypdfexportinstructions = pfcExport.PDFExportInstructions_Create();
PDFOptions Myoptions = PDFOptions.create();
//FONT
/*set option to set Monochrome color plot*/
PDFOption MyPdfOption_Color = pfcExport.PDFOption_Create();
MyPdfOption_Color.SetOptionType(PDFOptionType.PDFOPT_COLOR_DEPTH);
MyPdfOption_Color.SetOptionValue(pfcArgument.CreateIntArgValue(PDFColorDepth._PDF_CD_COLOR));
Myoptions.append(MyPdfOption_Color);
PDFOption MyPdfOption_Layer = pfcExport.PDFOption_Create();
MyPdfOption_Layer.SetOptionType(PDFOptionType.PDFOPT_LAYER_MODE);
MyPdfOption_Layer.SetOptionValue(pfcArgument.CreateIntArgValue(PDFLayerMode._PDF_LAYERS_NONE));
Myoptions.append(MyPdfOption_Layer);
Mypdfexportinstructions.SetOptions(Myoptions);//null is default
String modelLocation=""+Workingdr+"\\"; String drw_name = "Asm0001.drw"; ModelDescriptor desc1 = pfcModel.ModelDescriptor_Create(ModelType.MDL_DRAWING, drw_name, null); desc1 = pfcModel.ModelDescriptor_CreateFromFileName(drw_name); desc1.SetPath (modelLocation); draw=(Drawing)curSession.RetrieveModelWithOpts(desc1, pfcSession.RetrieveModelOptions_Create()); draw.Display(); draw.Export(""+draw.GetFullName()+""+ i1+"", Mypdfexportinstructions);
Its working fine .The code Exports all the sheets into one pdf. I want to to Export the sheets Individually
ddhini
(To:ddhini)
PDFOption MyPdfOption_Launcher = pfcExport.PDFOption_Create();
 MyPdfOption_Launcher.SetOptionType(PDFOptionType.PDFOPT_LAUNCH_VIEWER);
 MyPdfOption_Launcher.SetOptionValue(pfcArgument.CreateBoolArgValue(false));
 Myoptions.append(MyPdfOption_Launcher);
//Load Drawing Files....
String drw_name = ""+drawfiles[i]+".drw";
//Get total number of Sheets..
int nooffiles=draw.GetNumberOfSheets();
for(int no=1;no<=nooffiles;no++)
  draw.SetCurrentSheetNumber(no);
  draw.Display();
 draw.Export(""+draw.GetFullName()+"-"+no+"", Mypdfexportinstructions);
continue;
//draw.Export(draw.GetFullName(), Mypdfexportinstructions);
I code the individual sheets to print as PDF  in Jlink .Thanks for everyones help .
ddhini
(To:DavidBigelow)
@DavidBigelow
David I wish to do this by Jlink .
Good. Please read my previous reply again... it is the framework of how to accomplish your goal.
ddhini
(To:ddhini)
  draw.Display();
continue;
