Hi all,
I am giving dimension to an assembly model in creo and most of the times i have to use ordinate dimensions. Here I am stuck in a problem that if i accidentally give a wrong baseline for ordinate dimension then I am unable to delete it, like you would delete any normal dimension by pressing delete button or right click->delete. Am I missing something here, help me out please!
Attaching image for clarification.
Hello Sohaib,
It looks like you can Erase the dimension or use the Remove from State. Also, if you have selected an incorrect reference for the baseline, you can use the first icon, under Edit Actions - Edit Attachment dimension and then select a new reference for the baseline.
Amit
Hello Sohaib,
Amit
oh k so you cant delete the baseline dimension just giveit a correct refrence if is not given the correct one?!
thanks man.. ![]()
