Currently we have the following relation in our startpart
MATERIAL = MATERIAL_PARAM("CONDITION")
This arranges that the parameter MATERIAL is filled with value of the material parameter CONDITION. This parameter MATERIAL is shown in the BOM.
As with Creo 7 there is the multi-body added. In this situation it is possible to use multiple materials in one part. When this is the case there is a parameter PTC_REPORTED_MATERIAL created which contains the name (I think it's also the condition name) of the used materials separated by a ",", see below.
I thought I update the relation in our startpart (template) but it is not possible to use the relation
MATERIAL = PTC_REPORTED_MATERIAL
It then shows the error "Invalid symbol ' PTC_REPORTED_MATERIAL ' found.".
Somebody a solution?
From the documentation here: https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/index.html#page/model-based_definition/about_material_parameters.html
It states:
"The system parameter PTC_REPORTED_MATERIAL is used to report materials in the BOM table and to view all materials assigned to the part. You cannot edit this parameter. You also cannot use it in relations. At part level, the parameter PTC_REPORTED_MATERIAL reports all the materials assigned to all bodies in that part. At body level, this parameter reports the actual material assigned to the body."
I was hoping I am able to control the reported material somehow. What if you have for example 10 different materials used in one part, then the length of the generated PTC_REPORTED_MATERIAL become a bit lengthy to show in a BOM list on a drawing.
We now have Creo 11 and still the same problem But as this is quite common all other users should have the same "challenges".
Facts:
The challenge we have is
How to get this PTC_REPORTED_MATERIAL correct designated to Windchill?
How to set this in the drawing template? As an assembly has no PTC_REPORTED_MATERIAL, the template cannot be the same for a part or a drawing, that's not really convenient.
Currently we have solved this by using the parameter MATERIAL and a relation on parts to fill this with the material description and for assemblies set a relation to leave this parameter MATERIAL empty. So we can display this parameter MATERIAL on the drawing table. And also designate this parameter MATERIAL to Windchill.
Looking at the multi-body situation, it looks like PTC wants us to use the PTC_REPORTED_MATERIAL but I get the feeling they didn't make a complete usable solution...
