How to add "Annotation sets" to CreoView file
AndreasHellmann
Good morning,
I am wondering if anyone knows how to export or create "annotation sets" in a pvz file.
I know that simpreps and/or combined states can be included in to CreoView (*.pvz) files bycorrect settings in the rcp recipefile. These are exported as "viewables" to the CreoView file and can be selected under the tab "Viewables".
I have a PTC demo pvz file which has some kind of "Previews" to states. These can be selected under the tab "Annotation Sets" in Creo View - see attached screenshots.
>> DOES ANYONE KNOW HOW TO CREATE THESE ANNOTATION SETS??? In Creo Parametric, Pro/E or CreoView Lite/MCAD ???
Kind Regards and Greetings from Switzerland,
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Rudolf-Diesel-Str. 6
D-65439 Floersheim / Germany
phone: +49 6145 598296
mail: -
5 REPLIES 5
On 10/31/12 04:39, Andreas Hellmann wrote:
> Good morning,
> by correct settings in the rcp recipe file. These are exported as "viewables" to the CreoView file
> Lite/MCAD ???
In CreoView do this:
1. select the markup tab
2. markup as needed
3. File | Save Annotation Set
> Andreas
> Andreas Hellmann
> mail: - <">mailto:->
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
These annotation sets are pretty handy. They can also be attached to an ECR/ECN to further define the change
[cid:image001.gif@01CDB74E.68E0D6B0]
Steve Vinyard
Application Engineer
Hi Steve,
How do you attach the annotations to a change order? PDMLink 9.1 M060
Thanks! Kathy
If you create an annotation on a CAD Document you can then add it on the ECR via the Annotations options. I believe this options also exists on the ECN as well. The help menu should have information on it as well
[cid:image001.gif@01CDBCD0.765BA770]
Steve Vinyard
VeqTor
(To:SteveVinyard)
Hi all,
Our team is working extensively with Annotation Sets in Creo View.
We are wondering whether Annotation Sets can be created in Creo Parametric as well -- and if yes, can somebody pls. provide a link to how this is done?
Thank you
