How to adjust size of icons in Creo 4.0 ribbon?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Does anyone know how to change the size of icons in the ribbon of Creo 4.0?
Bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I'm don't think you can change the actual icon sizes but you can hide the command labels.
Before:
After:
How to hide them:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
This might be worth reading as well:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Icon in Creo cannot resize. When resizing the Creo Window group/icon can collapse as it works on group policy to decide which group needs to collapse first.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Contrary to what @TomU and @Mahesh_Sharma said, you can resize icons (you can switch between large and small version of the icon). To change the size of the icon, first right-click the ribbon and select Customize the Ribbon to display Creo Parametric Options dialog box. Then you can simply right-click desired icon and select Small Button or Large Button to set the icon size.
For example, all icons set to Small Button:
And all icons set to Large Button:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
This is great to know! However, small buttons seem to be the default option as well. I'd like and option to go "smaller" than the default option.
Bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Is there an easy / simple mean to set all icons to small buttons instead of doing one by one ?
Best regards,
Philippe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thanks for your answer .... this is quite hard to believe that PTC proposes such a low level of UI admin capability.
I think it is a good UI enhancement idea for PTC.
