In Wildfire you could highlight the dimension and adjust it using by grabbing the end of the line. In Creo I can’t figure out how to do this?
I think this is someplace in Dimension Properties.
Shift-drag
As Antonius said, hold the Shift key while hovering over the dimension. Here is the document for this:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS66313&source=tssearch
