I have a part that I need to apply a torque to that makes contact with neighboring parts. I need this torque to be applied before the main loading of the system applied to the assembly.
How would one apply one force/moment analysis feature before additional loads are applied when running the analysis?
Need the assembly to introduce the pre/stress (torque) before the main force is applied to the assembly.
When the main force is applied to the assembly, it binds the parts and prevents the torque stress from being applied to the contacting parts.
Thanks for any help you can provide,
Don Anderson
Found what I was looking for. Needed to run a static analysis for the Torque Preload and then reference The Torque analysis in a Pre-stress Analysis.
Don
Don
