How to avoid auto-regenerations in an assembly of 6k+ parts?
JS_9824412
Hi everyone,
It must be an answer for this one, but can't find it... When working on a feature in an assembly, I changed mind and "Cancel" the action, the CREO regenerated automatically all the assembly with more than 6k parts. It must be an option to set to avoid the automatic regeneration. No?
I am using CREO 6 in offline mode.
Thx,
JS
tbraxton
22-Sapphire I
(To:JS_9824412)
In addition to the config option provided by @BenLoosli  you should also consider setting components in the assembly to read only so they are not regenerated at all even if you initiate a regeneration while working in assembly mode.
http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/part_modeling%2Fpart_modeling%2Fpart_five_sub%2FAbout_Read_Only_Features.html%23wwconnect_header
Involute Development, LLC
Consulting Engineers
4 REPLIES 4
BenLoosli
(To:JS_9824412)
Have you tried this:
  • Disable Auto-Regeneration setting the configuration option "enable_auto_regen" to "no"
tbraxton
22-Sapphire I
(To:JS_9824412)
@JS_9824412 wrote:
Hi everyone,
Thx,
JS
do you really need to work with 6k parts assembly ? Have you tried using simplified representations ?
Martin Hanák
I needed to take some measurements (for creating simulation model) of the complicated product, which I am not familiar at all. There are numerous Simp Reps already created in the model, but I am not familiar with these Reps either.
