Need help to convert thousands of mi files to dxf.
I have tried dwgdxf tool. Success rate is near 50%. This toll can only read mi 2.5-3.5.
Creo parametric can import all the mi files individually and successfully export to DXF. Couldn't import by batch in CREO parametric. Can anyone suggest me a good working method?
I have tried dwgdxf tool. Success rate is near 50%. This toll can only read mi 2.5-3.5.Creo parametric can import all the mi files individually and successfully export to DXF. Couldn't import by batch in CREO parametric. Can anyone suggest me a good working method?
https://www.ptc.com/en/support/article/CS121442 mentions following ... As Workaround use Mapkey (mapkey.ttd) in Creo Distributed Probatch.
