How to break reference
CAD_user
In an assembly, I made a copy of surfaces, from another part. Now I want to break the dependency to the original part.
How I can do this?
TomU
(To:CAD_user)
The key is to collapse the copied surface(s) into the independent geometry feature.  Watch this video:
7 REPLIES 7
TomU
(To:CAD_user)
CAD_user
(To:TomU)
I don't have the option to back up references available within the copy.
I don't have also Windchill...
TomU
(To:CAD_user)
CAD_user
(To:TomU)
Ok. Fine.
and if i don't have the command available?
TomU
(To:CAD_user)
You can't pick collapse until the independent geometry feature exists first.  You also have to select both of the features together before you can pick collapse.
CAD_user
(To:TomU)
Sorry, but I still don't found how to do it. I select the copy, but the collapse, isn't available. So how can I create the independent feature?
TomU
(To:CAD_user)
Video is working now.  Watch it and see if it helps.  If for some reason you can't create an independent geometry feature, you could probably import a STEP file (of anything), delete all the stuff inside the import, and then collapse your surface into that feature.
