Hello!
When I create a coordinate system in a layout (I use to place components automatically in the assembly), I can not change the text font and I can not change the name of the coordinate system.
This behavioral is present only by coordinate system.
Do you have some advices for me?
Thank you!
OK! Nice! Thank you! For new notebook is working. Some ideas how to apply this to "old" one?
New created annotations are with the new font, but the existing annotations do not get the new font 😞
@PI_6131154 wrote:
Hello!
Thank you!
1.] CSYS names can be changed in individual parts/assemblies.
2.] font of drawing test items can be set using drawing/detail option named default_annotation_font
See https://www.youtube.com/watch?v=K3uBj8ofe6M video starting at 5:30 time.
Hi!
Thank you for the help.
My question is according JUST in LAYOUT /now called Notebook/.
@PI_6131154 wrote:
Hi!
1.] I do no know how to rename CSYS created in Notebook/Layout ... please assk PTC Support.
2.] font of Notebook/Layout text items can be set using detail option named default_annotation_font
See https://www.youtube.com/watch?v=K3uBj8ofe6M video starting at 5:30 time for inspiration.
Das alles kenne ich, funktioniert unter LAYOUT nicht
I created new notebook in Creo Parametric 7.0 and set detail option named default_annotation_font.
Notes and CSYS names are displayed in font I set using this option.
I think existing annotations have font assigned manually. Edit note properties and turn on Default option.
Hi Martin!
I got it with the font. Annotations are not the problem. Always I speak about the "annotation text of a coordinate system in notebook". The problem with the font is done! Thank you.
Now is still the problem with the font size of "annotation text of a coordinate system in notebook". I can not change it. In not so important issue, but should be interesting to know if it possible to mage it.
Of course the problem with no changing of the name of "annotation text of a coordinate system in notebook" still be.
@PI_6131154 wrote:
Hi Martin!
I guess the size of CSYS names is hardcoded and cannot be configured. Please ask PTC Support to be sure.
