How to change the layout of these dimensions in a leader note to ISO Tolerance Display Style?
MTK143
6-Contributor
I am having this issue trying to get this note fixed (image 1). With the other dimensions I have on the drawing, I set them to iso but can't do it to the notes.  I tried setting the drawing properties but didn't work. End goal is to look like image 2.
6 REPLIES 6
Mahesh_Sharma
22-Sapphire I
(To:MTK143)
Set detail option default_tolerance_display_style to value std_iso. This will work for new dimensions.
Further details are in article at https://www.ptc.com/en/support/article?n=CS24262
I hope this will help.
MTK143
6-Contributor
(To:Mahesh_Sharma)
Is there anyway to correct the ones already on the drawing??
Mahesh_Sharma
22-Sapphire I
(To:MTK143)
Uncheck "Iso Tolerance Display style" under Display tab on Dimension properties dialog box for specific dimension.
MTK143
6-Contributor
(To:Mahesh_Sharma)
I did that for the dimensions already but this is a leader note the had &d### in it.  Any ideas?
Mahesh_Sharma
22-Sapphire I
(To:MTK143)
Can you simplify and share drawing?
MTK143
6-Contributor
(To:Mahesh_Sharma)
For my company policy I can't share the drawing but I can take little snips here and there as long as it doesn't contain certain info. I attached another snip. hopefully this clarifies.
