Using a helical sweep allows for the creation of a winding with a consistent thickness, but since the coil height is 18mm and the wall thickness is 12.5mm, bending the model created with the helical sweep will cause interference with the coil. If you have a good method, please let me know.
Are you asking how to model wires wrapped around a core such as this?
