How to create a new model from a comparison model
ptc-4364335
3-Newcomer
CREO 7 will not allow me to save and create a new model from a comparison model. Does anyone have a solution for how get around this?
StephenW
(To:ptc-4364335)
You didn't give any details of what you have tried or your system, such as using windchill pdmlink. So we will have to start with basic stuff. You can rename a part in windows but don't expect an existing assy to find it with the new name.
File - save as (if a part, it's just entering a new name, if assy, you will have to decide if you want new names for sub-levels or use existing)
File - save as save as backup (to copy an entire model with the same name to a different directory)
Using pdmlink, you can use the save as function from with pdmlink.
Hi Stephen,
Latest and released version of a component and drawing is v2.0, and ideally I would like to create a new part and drawing from  v1.0
/Thomas
StephenW
(To:ptc-4364335)
I don't understand. You're not talking about filename? You are talking about version #? Are you referring to version in PDMLink or are you talking about version on filename. Or something else?
PDMLink version vs. filename version:
