How to do total of table content?
  • August 8, 2012
  • 2 replies
  • 8838 views
the lenght in table is driven by parameters..
i use relation in assembly to add all the lenght parameters
and is working fine but...
now, i need to add two new angles in this assembly and i want automated addition of length by the time i add them up in assembly.
is it possible? or any solution plz share
Hi Dalbeer...
Are you looking for a simple Summation of the lengths in your table? If so, there's literally a Summation command for repeat regions that can handle this (provided those length values are real numbers and not strings).
If I'm misunderstanding your question, please let me know. If you need a picture or some quick step by step instructions, let me know.
Thanks!
-Brian
plz do share
Hi Dalbeer...
Not my usual quality but it's 5:30am and I haven't slept! I hope this gets the point across. Write back if this doesn't make sense.
I really, really hope that makes sense. The Summation tool is useful but rarely used because it has some idiosyncrasies that need to be heeded for the function to work. This should be what you're looking for. Good luck!
Thanks!
-Brian
GregoryPERASSO
All
please find that post about weight roll out
Weight rollup in Windchill 10.1 M040
think that need have to be handle in a dynamic cognos report or WPA if you are using full Windchill solution
(but same problem for lightweight Intralink solution)
Due to the dynamic nature of a multilevel structure ...
regards
