How to edit the name of the folders and profiles in Creo Advanced Framework Extension (AFX)
Armando_Pirlo
referring the article CS392162, I'm not able to edit the name of the folders.
In my example I need to add the mechanica beams and I want to maintain the original ones.
I already create the folder structure, as you can see in the image attached:
- simulate
    - steel_beams_mm_mechanica
    - steel_beams_inch_mechanica
I want to change the label of the folders:
- SIMULATE
    - MECHANICA MM
    - MECHANICA INCH
I need it in two different languages, english and another one.
Thanks in advance
Hi @Armando_Pirlo ,
how did you modify your afx_custom.txt text file?
Maybe this will also help you to understand how the customization needs to be done:
https://youtu.be/-iLYU-YT8e4?si=L-5LDfymiBw5naD5&t=434
Samuel Brantner
B&W Software GmbH
In our B&W Webinar Week 2020 there were various presentations, which we would like to provide here, too. In "What's new in AFX?" you will be introduced to the latest features of Advanced Framework Extension. For more information about the software, please use our contact form on the website: ...
Hi @Armando_Pirlo ,
Samuel Brantner
B&W Software GmbH
Hi Samuel,
thanks for the link.
I solved with your indications.
My error was the customization_path option definition.
