How to enable lock file and unlock file in my creo file window
AR_10002308
7-Bedrock
In my creo's manage file window lock file or unlock file option is not available. is there any configuration setting needs to be changed for that??
7 REPLIES 7
StephenW
(To:AR_10002308)
I think you are referring to File - Manage File - Lock. I am not 100% sure but I believe this is only available for users of Windchill PDMLink.
You're right, In my wind-chill workspace i am not able to see this lock option. Is there any settings to be changed for that?
In windchill, select the file/files then File > Lock
If the column is not visible, select the dropdown for a column then the columns and check General status.
This is my wind-chill screen. I am not having "lock", "unlock".
according to https://www.ptc.com/en/support/article/CS292262
There is a requirement for the objects in workspace to be checked in at least once before the option is available
Martin Hanák
Are you using the in-session browser?  I don't believe you can lock a file from an external browser.
