We are currently experiencing a service disruption impacting community and support login. Our teams are working to resolve the issue.
In my creo's manage file window lock file or unlock file option is not available. is there any configuration setting needs to be changed for that??
I think you are referring to File - Manage File - Lock. I am not 100% sure but I believe this is only available for users of Windchill PDMLink.
You're right, In my wind-chill workspace i am not able to see this lock option. Is there any settings to be changed for that?
In windchill, select the file/files then File > Lock
If the column is not visible, select the dropdown for a column then the columns and check General status.
This is my wind-chill screen. I am not having "lock", "unlock".
according to https://www.ptc.com/en/support/article/CS292262
There is a requirement for the objects in workspace to be checked in at least once before the option is available
... another information source ...
Are you using the in-session browser? I don't believe you can lock a file from an external browser.
