How to export 3D annotations to stp-file? (Creo 3.0 M080)
mhergenhan
2-Explorer
Is it possible to export 3D annotations from Creo 3.0 into a stp file? Want to make it visible in another CAD software ...
3 REPLIES 3
in https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS134385 I can see this information:
intf3d_out_annotations
intf3d_out_parameters
STEP
For annotation and parameter export support, set config.pro option step_export_format to ap203_e2 or ap214_is​
  • In Creo Parametric 4.0 use an Export Profile to set the Application Protocol to ap203_e2, ap214_is​, or ap242_e1 and check the boxes next to Annotations and Parameters
Note: I did not test the above information.
MH
Martin Hanák
jgu-3
2-Explorer
(To:MartinHanak)
It is working..
but it is showing all annotations in one view.
is it possible to split the annotations into different sheets similar to the creo model.
DennisRehmer
(To:jgu-3)
When I bring step file into Creo View, I do NOT see any of my annotations. How do you get them so they are visible.
Dennis
