How to export a picture of our project in Creo Element/Direct in PNG format ?
AlexandreChartr
7-Bedrock
I wanna know how can I export my first modeling project in PNG format
Thank you to answer me ?
PS: You can also answer me in French, because it's my native language !
4 REPLIES 4
I typically do a simple screen capture so I get exactly what is on the screen.
You can also set the rendering options to output PNG but I am finding that this doesn't work for some reason.
For render images, you might want to output a different format (TIFF is recommended by most) and converting it to PNG in another program.
Now I have to figure out, or CS has to figure out why PNG is not working.
Antonius is write! Using a print screen is the easiest way to snapshot the screen. Another method I use is to use a capture/editing software called SnagIt from TechSmith. This software is on of the coolest graphics capture/editing software's I've seen. Very simple to use, and very intuitive, unlike ProE, Wildfire, Creo, . . . . . .
Thank you both
I also want to recommend a tiny software called Greenshot. It´s very similar to SnagIt but it´s freeware.
When you hit the "print screen" key you can define a area to capture and then you have a lot of options available:
By default it saves in the PNG format like you are looking for.
The image editor has good tools like editable text boxes and arrows. Highly recommendable.
