How to get a flat pattern for swept Blend?
rkumar-7
6-Contributor
In sheet metal i'm having one part. It Unable to get a flat pattern in CREO 3.0.
9 REPLIES 9
Its an alternate method but gives you the same result what you want.
Please find below image for your solution.
Please try with the features in the model tree what i used.
Jimmy
rkumar-7
6-Contributor
(To:jvadalia)
Thank you for your support jignesh vadalia..
rkumar-7
6-Contributor
(To:jvadalia)
Hi jignesh vadalia
       I tried your solution but i'm not able to flat pattern. if i go to flat pattern the surface is not selecting. Can you sent me that part what are you trying.
Hi Raj,
please send me your email ID.
I will send it to you.
Jignesh
rkumar-7
6-Contributor
(To:jvadalia)
Hi jignesh vadalia
                 rajkumar@cadopt.com This is my email id
Regards
Rajkumar K
Hi Raj,
hope you got the solution..
If yes the please mark the answer correct.
Jignesh
Hi Raj,
Jignesh
mmello
(To:jvadalia)
StephenW
(To:mmello)
