I have created assembly with skeleton model.
I have assigned a parameter part_thickness=0.179 in the skeleton model.
Now I want to create a part with this thickness value with this parameter (which is define in the skeleton model).
How to import parameter which is created into the skeleton part, to the part part file?
Thank you for sharing this information
Is it possible to get skeleton parameter into part relation?
please replay uploaded video. It works if assembly is loaded in session, only.
