How to keep the "Enable preselection highlighlighting" option permenantly ON in Creo "Selectoin" tab
hvyas-3
Hi All,
 Every time I open CREO the option " Enable preselection highlighlighting" is turned off. I ticked it on and then tried to save the config file. still the next time I restart the CREO the option is unticked by default. Is there any solution to it? I would appreciate your help. Thanks so much in advance.
tbraxton
22-Sapphire I
(To:hvyas-3)
Make sure this is saved to a config.pro file that is loaded when you start Creo.
Involute Development, LLC
Consulting Engineers
tbraxton
22-Sapphire I
(To:hvyas-3)
